Marco- I see that you have stock on the beam combiner again- can I position this right out of the 1st mirror- that is where I have room for it. Thanks
Gene
Pro 25mm beam combiner
GeneMpls
Re: Pro 25mm beam combiner
Hey Gene:
Yes you can. The new combiner is a fixed version. It should work better on the beam alignment issue happened with beam expander.
(in China)
(in China)
GeneMpls
Marco- one last question before I order- my laser is 130w- this 25mm lens will be OK with that, right? Thanks Gene
It depends on the size of the laser beam spot. So, you need to measure the beam size.
Maeco
Maeco
GeneMpls
I am getting 7.55mm an inch away from the tube (before the first mirror) thanks Gene
I suggest 1.5X beam expander. 2.0X may be too big for regular machine. If you have 7.55mm beam diameter, you may get 12~14mm diameter right before the inlet hole from the laser head. If you get 2.0x, you may get 16~18mm beam diameter. I think it is just too big for 25mm reflection mirror for for a common laser head.
GeneMpls
Marco- I get 8.6mm at the farthest corner of the machine (1300x900) at the cutting head. I am not sure what a beam expander does or where it goes.
gene
gene
Hi Gene
Discard my last post because I thought you wanted to use an beam expander. You are good to go
(Training in China)
(Training in China)
