Z axis problems
ukanduit
Z axis problems
Post by ukanduit »
I think my Z-axis stepper is bad.
I checked the continuity from one end of the cable to the other and it is good.
I plug y axis motor into z axis controller and it works.
I plug z axis motor into y axis controller and it does not work.
So is there something else to check?
Thank you.
ukanduit
Re: Z axis problems
Post by ukanduit »
I found the problem. The current was set wrong. It should be set to 1.5A
