While reading this forum I ran across this;
viewtopic.php?f=70&t=2507
I don't want to put anymore money in my 40W but I want
the X7 DSP and the XLE 900*600 table.
Is the diagram correct for this setup and would the other
components mentioned work ? I'm not worried about the
laser & PS right now, just wanted to get the motion control.
Or is there a parts list for whats needed ?
I looked for hours trying to find a manual for the X7.
XLE 900*600 with X7 DSP
litterbox99
DonL
Re: XLE 900*600 with X7 DSP
The complete conversion kit has everything you need to get started and obtain motion control less the stage and cabinet... Here is the LO-X7 Manual although it is under a different name....litterbox99 wrote:While reading this forum I ran across this;
Hope this helps....
Don
- Sinjoe Tech Awc708c Lite Controller User Manual SJ 7.10L.pdf
- (2.96 MiB) Downloaded 264 times
