Don't get fool by the CW3000 because it is NOT a water chiller. The CW3000 is just a water radiator cooling unit without AC compressor so it wont do cooling. However, a lot of folks through that it is a chiller and look at eBay seller 99.9% claim that it is a "water chiller"
After long consideration, I decided to take this project to my team in China to develop a small water chiller. The unit is perfect for the K40 (35W) or any machine running full time and 24/7 with a 60W tube. It will work well for a 80W laser machine running on part time, say ON for 20min, Off 1min or 80% of full power. It should works the same way on a 100W system Of course the Off time should be a bit longer while ON time should be shorter or 65% of full power. I'll get more result once the prototype is completed in next two weeks. I'm expecting first batch of production launched on Jan 10th,2016
Cooling Power: 800W (estimated)
Compressor power: 600
Voltage: AC110V, 60Hz
Current: 3A
Operation temp: 35'C (95'F)
Suggest laser tube: 60W (full time),80W (Part time)
Cooling temperature: 23'C (73.4'F)
Warranty: 1 year
So, one will ask what would be the price?
Price is: $425
