Sealing high voltage connection at the laser tube
geartech
Post by geartech »
The 32w that came with my K40 had a piece of silicone tube slit and pushed over the HV connections and then filled with what looks
like clear silicone sealer.
My K40 came with a tube of 703 gui xiang jiao packing adhesive. This stuff is a white thin silicone sealer/adhesive
Wonder if that will work or just leave the connections open?
I haven't had any issue with arcing but I just don't like 20kv out in the open.
Anyone have any advise for me?
Re: Sealing high voltage connection at the laser tube
Post by Techgraphix »
The silicone in the sleeves will not insulate and prevent corrosion but also fix the wrap or connector so it won't come loose due to vibrations.
SWMS
Post by SWMS »
Yeah, I covered mine in quick curing silicone. Any builders one will for showers etc will do. Make sure the contacts are dry and you are doing it in a nice dry area. Tried it with a hot glue gun at first. Forget that!
Users browsing this forum: No registered users and 60 guests
