I'll be in the market for a new laser cutter next year...
Craig_Johnson
Post by Craig_Johnson »
I'm thoroughly disgusted with my refabed FSL 40w laser. I like the 608 controller and other parts I purchased here but the frame and box of the FSL is just not up to the challenge. I'm thinking of getting a 180w cutter that uses the 608 controller and thought I'd look here before I try Alibaba. As long as I have a 9x12 cutting area I'll be fine. Any thoughts? I guess I could build one from scratch too, but was hoping to save myself some work.
Re: I'll be in the market for a new laser cutter next year..
You may try this one: 1200x900mm
http://www.lightobject.com/Pro-1200x900 ... -P828.aspx
We can put AWC608 or the X7, or the R5. All this DSP are having similar design with powerful features.
Return to “Laser products”
