Upgrading tube and mirror mounts
Hey all,
I just wanted to get options from some of you that may have gone down the same path I'm thinking of taking. Have any of you upgraded the mirror mounts and/or tube mount in your K40 with these:
http://www.lightobject.com/Pro-Laser-Tu ... -P651.aspx
http://www.lightobject.com/Pro-20mm-ref ... -P589.aspx
I just wanted to see if anyone has any feedback - such as, do they actually fit/work in the K40's.
Re: Upgrading tube and mirror mounts
Hey Marco, do you happen to know off-hand if the 60mm tube mounts you offer for sale can be used in a K-40 machine ?
It won't work because the K40 has very limited- space
Marco what focus lens you recommed k40 machine for best cutting wood 3mm ply or gabonTech_Marco wrote:It won't work because the K40 has very limited- space
http://www.lightobject.com/18mm-Laser-h ... -P701.aspx
http://www.lightobject.com/High-quality ... -P799.aspx
is those ok? which is better shorter or longer focus?
I'm no expert Teacdance, I will leave that to Marco but just for your info, I have the DK40 albeit upgraded to X7 standard. I have both the 38.1 and 50.8. I am cutting 2mm and 3mm acrylic for flight sim panels and the 50.8 does the best job in my opinion. Have a search around other posts on the forum and see what others are using until Marco gets back to you. What works for me might be different for others.
thanks weebweeb wrote:I'm no expert Teacdance, I will leave that to Marco but just for your info, I have the DK40 albeit upgraded to X7 standard. I have both the 38.1 and 50.8. I am cutting 2mm and 3mm acrylic for flight sim panels and the 50.8 does the best job in my opinion. Have a search around other posts on the forum and see what others are using until Marco gets back to you. What works for me might be different for others.
i just find this post
http://lightobject.info/viewtopic.php?f ... 462#p11821
i have that k40 machine using 4 years allready and 50.8 lens that cut fine 6mm acryl but not wood 2mm go good but 3mm barely. maybe 30.1 lens get more better?? or is time to change tube how meny years is tube life?
If you want to engrave better, then go for 30.8mm. For cutting 3mm~5mm, you better stick with 50.8mm
OK i allready order those i have to do little test.Tech_Marco wrote:If you want to engrave better, then go for 30.8mm. For cutting 3mm~5mm, you better stick with 50.8mm
yep 50.8mm is better... 30.8mm fit just k40 machine and it's hard to focus if you don't have lifted table.. I have to maybe buy that nextTeacDance wrote:OK i allready order those i have to do little test.Tech_Marco wrote:If you want to engrave better, then go for 30.8mm. For cutting 3mm~5mm, you better stick with 50.8mm
