I've tried numerous times now to install lasercad yet it installs in chinese everytime.
Ive tried the latest version and the previous version. No antivirus running.
Also tried this but there are no languages in the drop down
viewtopic.php?f=8&t=1841&hilit=lasercad+chinese
I'm at a loss as to why it wont install in English.
The config in the installer is set to install in English and I select English from the drop down during installation.
Any help would be appreciated
Impossible to install lasercad in english
Re: Impossible to install lasercad in english
I think the following will work:
Remove the older versions from your computer first, so deinstall and remove the remainders from your harddisk.
Check the registry if there is something left of LaserCAD and remove that too.
Download the complete ZIP-file (http://lightobject.info/download/dsp/La ... V7.57B.rar) and unzip it to your Desktop.
Open the map and doubleclick on setup.exe
In the first window that opens you'll see aa pulldown-menu where you have to select English.. etc etc.
Yeah tried all that.
Managed to figure it out though.
It seems it wasnt installing any language at all. The tools were showing as question marks.
I just installed then copied the english config file over to the installation folder.
Worked perfectly.
Worked perfectly.
