Already problems with upgrade.
Bolt Action Pen
Post by Bolt Action Pen »
Reading the instructions for removing the flat bed says that there are 5 screws to remove. My machine appears to have rivets rather than screws. Is that a correct assumption? There is no way to insert a screwdriver, Torx driver, or another kind of tool.
Are these really rivets, and do I need to drill them out and replace with screws?
Thanks much.
Darrell
pwoyorkie
Re: Already problems with upgrade.
Post by pwoyorkie »
Having removed this myself today there are 5 screwson the flat bed itself and 5 under the unit.
I only have experience (or lack of) with my own machine though so its quite possible there are rivets. Thats unlucky if its the case :(
I hope your upgrade goes smoother than mine. Im not much further than you and stuck also lol
Bolt Action Pen
This is what I see. There a some bolts with nuts showing, but the photo in the manual indicates there are 5 spacer tubes supporting the flat bed. That's what has the funny rivet looking things.
Bolt Action Pen
I figured it out. They are, in fact, screws. Don't know what type, as nothing in my tool chest would work. I did finally get them out using a pair of vice grips. Think I'll replace them with something more standard when I put it back together.
