Hi, ~I don't do a lot of engraving, mostly cutting, but I need to engrave a really nice surface, however, I can't seem to get a good result wiht engraving bmp's all of a sudden. If I draw a box in lasercad and change it to engrave instead of cut, it does so beautifully, but when I try to engrave a jpeg, gif or bmp it just does the engraving in a series of lines about a mm distant. the bottom square is made using the box method and the text is a bmp
I know it could do really nice engravings not so long ago, I haven't changed anything bar lowering the overall speeds, as it did this not so long ago.
It seems to control the y axis normally when its drawn in lasercad but when you import a jpeg it seems to advance the head too much at a time.
Cheer,s tim.
