Problem Importing AI Files into LaserCAD
JNasiatka
Post by JNasiatka »
Hi -
I'm having some problems importing AI files into LaserCAD. When I do the import, the image comes in as
either jibberish or all the objects are scattered all over the place. Any color information seems to be lost
as well - all the lines are black, not red/blue/whatever.
If I save the file as a SVG and run it through this online converter it then loads properly:
http://online-converting.com/
I'm using the latest version of Illustrator, and saving the file with no compression. Do I need to save it in a
prior version of Illustrator? If so, which one?
Also, is there any chance that SVG files could be read in by LaserCAD?
Closeup of the import
File imported into LaserCAD
Picture of the Illustrator file
jjpumphrey
Re: Problem Importing AI Files into LaserCAD
Post by jjpumphrey »
I have the same issue with AI. I am running the Adobe Creative Cloud version and what I found to work is doing a save as a Japanese AI ver 3. When the file is imported into LaserCad there is a little junk that is easily cleaned and then I can work with the rest of the image for sizing and positioning. I'm still playing with other methods but this is the best so far that works for me. I have come across various AI files that just will not convert, not sure why. I have some files from a stock vector image supplier and most of those files need some conversion as well. I have read in another post that there is an update to LaserCad in the works that will make AI files more compatible.
James:
Check your "PM"
Let me know how it goes
SWMS
Post by SWMS »
LaserCAD has never imported AI files very well. I work in a program, open it in CorelDraw and click the Macro button. It works well like that. I know its not a fix but its an effective workaround.
