Hallo
this mording my machine explose.....don't worry it's ok for me but my laser don't work anymore
I see only electrical lamp in the back of machine. I don't know if the laser is broken or the power supply.
You can help me....becouse I think is broken the laser tube....what you think of this?
My machine is dead
barillo66
barillo66
Re: My machine is dead
Hi
the water pump stopped working, I did not see, I think this is the cause, now the laser tube does not work and makes sparks on the anode. I think I have to replace the laser tube. I must contact Marco.
barillo66
Can someone help me ... how can I tell if the tube is broken laser or the power supply is broken. when do the laser pulse with the key forms a spark type arc on the anode of the tube. everything else appears to be working...
hi there
where do the spark go to?? sometimes it helps just to carefully cut the old connection off and wind the wire new around the stud then put a piece of pvc hose over and fill the hole all the way down to the glass with silicon caulk.
barillo66 wrote:Can someone help me ... how can I tell if the tube is broken laser or the power supply is broken. when do the laser pulse with the key forms a spark type arc on the anode of the tube. everything else appears to be working...
barillo66
hi Waltfl
I believe that the tube is broken, there is a lot of water in it and then I think it broke my inner glass flowing cooling water. Surely this has happened because the water pump stopped working without my noticing. We need a new tube ,all here.Thanks for your interest
Alfonso
Alfonso
