Check incomplete work error
Ihrke052
Post by Ihrke052 »
Hello,
I plan on upgrading my k40 but decided to test it out before getting the upgrade. I keep getting an error that simply says "check incomplete work last time, continue?" If I click yes it resets, if I click no it stops. It happens at random times during an engrave but typically about 30% in on a job. Any thoughts would be appreciated!
cefs
Re: Check incomplete work error
Post by cefs »
I am no expert as I am still building mine, but could it be that the control board is receiving an error/fault signal, maybe from interference. I would also check the wiring for safety interlocks like the door, water protect and limit switches.
Ihrke052
Post by Ihrke052 »
As far as I know the standard k40 machine doesn't have interlocks/safety devices. Most people add those after.
I know a lot of people have had issues with the moshidraw software and ultimately I will switch it out. Was just curious if there was an easy fix or if anyone knew what it meant. I messages the seller to see if they can offer an explanation so well see what they say.
