Water evaporator radiator - WC-WAT300
Blasttiod
Post by Blasttiod »
Just going to order the radiator(WC-WAT300) from you and a fan(s)/tubing. My chillers packed up and they are not cheap to replace.
Can you just tell me:
I see you mention that a 15cm fan is suited. Does the radiator have fixings for the 15cm fan?(if not then I might get two of your 12cm ultra strong 200cfm fans instead. That way i can use either both fans on at once or just 1 fan depending on how warm the water gets)
Also are there connections on the radiator for the tubing to go onto?
Regards
Kevin
Re: Water evaporator radiator - WC-WAT300
See image
What's wrong with your water chiller? How big of your tube?
If you're running 60W or lower, you may use a water radiator. But anything bigger or tube need to run long operation, then a water chiller is better
Blasttiod
Post by Blasttiod »
Thankyou for your reply.
Does the radiator come with the connections for the silicon tubing?
Also will your' Monster 15cm fan' you sell screw straight onto the radiator.
Regards
Kevin
That should work if I'm not forgotten. I believed that I tried it once before.I can double check on Monday
ivantandy
Post by ivantandy »
The monster fan I bought from LO did not fit the radiator's threaded bosses... I was unable to get marco to do anything about it. he just stated the manufacturer changed the product.
Blasttiod
Post by Blasttiod »
Hi Ivan,
Thanks for letting me know.
Other than that does the radiator cool the water enough and did it come with the tube fittings on?
Regards
Kevin
The monster fan didn't fit after trying today
Only the AC fan will fit. I can det you AC220V fan
There is no special fitting included. It is copper wire with 8mm diameter(need to measure to confirm). Silicon tubing will do the job well though
AC fan fit WC-WAT300 water radiator
Not in stock, special order only
