Do I really need LaserCad?. Is there another program that I can use, I opened lasercad an found it a bit useless, when open a DXF file all the holes turned into squares!!
not working as it started with engrave an black colour, worked out how to change to cut, but the colour thing is a bit annouing an can't delete a colour if required,
the drawing, accually the whole DXF file was a complete shamble. None of the corners were rounded an holes square or diamand shape.
So far I'm not empressed about the lasercad prog.
Neil
