icon for LC shows still version 5.82
Post by waltfl »
Hi marco
I installed the latest version 5.85 of LC programm but the programm header still shows 5.82 is that supposed to be so??
did you check the new cards, they are OK especially the USB part with the USB stick connector and the LCD??
please let me know that I can send you thre old one on monday.
thanks
wctx1977
Re: icon for LC shows still version 5.82
Post by wctx1977 »
waltfl wrote:Hi marco
thanks
I had the same issue when I installed the software but I quickly found the solution. Just uninstall any traces of the old version and empty your recycle bin then install the new one. Hope it works for you.
Edgar.
Programer Li
Post by Programer Li »
遇到此种情况 是因为安装程序没有覆盖掉原来已经安装的程序的文件
解决的方法:先卸载之前的版本,再到安装目录(如:C:\LaserCAD)下删除所有文件,然后再重新安装LaserCut5.85。
Programer Li wrote:遇到此种情况 是因为安装程序没有覆盖掉原来已经安装的程序的文件
Translate:
This is because the new installation didn't write over the eixisting software.
Solution: Before the installation, uninstall the old version. Then remove the whole folder (ex: C:\LaserCAD) into the garabage can. Then re-install the software again. It will fix that.
