Laser cad 5.5.2 / DSP 2012 Operating issue
jhartman46
I am able to move the laser head from the computer with no problems but if I try and Run Box, Clip Box or cut a box that was drawn I get " To select the file! " on the LCD panel and it won't run. Can someone help with this problem?
Gadroc
Re: Laser cad 5.5.2 / DSP 2012 Operating issue
Make sure you have downloaded a job from the computer first. When you click download on the main screen a dialog pops up. You have to click download on that screen before the job is sent to the DSP.
jhartman46
Thank You, I didn't understand the download feature which is different from what I was running before.
