Hi marco
did you find out what's the reason why my USB connector on the DSP card does not work??
I try many times now to copy files from the DSP on to a USB stick there comes the message " copy error"
I have uploaded a few files to the same stick out of laser cut 5.7 from the computer it works perfect I can copy on the stick and also re-open from the stick into laser cut 5.77 it works
if I wana load a file from the stick to the DSP there comes the message " no U disk"
did somebody else try this ? did it work?
please let me know
a also wishe everybody a very mery christmess
U disk not working
Re: U disk not working
Walt:
I think I told you already that there was a problem with copying file from the main board to a memory stick and the programmer is working on a upgrade patch. Until then, you should do copy direct from PC to the memory stick in the mean time.
hi marco
i thought it was solved allready yes thats what I do now but it is just for the future because I can not use the USB stick on tyhe DSP
but thanks anyway
but thanks anyway
Tech_Marco wrote:Walt:
