how to safe the file with the new DSP
Post by waltfl »
Hi all
I wondering how I can safe the file after it worked out with the acuracy what I need because I try this to safe it on my harddrive but when I reload it failure m,essage comes up that the file can not be loaded if I safe it in the LCD and recall it after same other work is done the measuremnets or complete off before I recall it I hit the resett botton and the machine goersw in the home position no problem
what do I do wrong?
Re: how to safe the file with the new DSP
Post by waltfl »
hi all and marco
did anybody ever try to safe a file from the DSP to a USB stick over the U file USB connector on the new DSP controller?
I try this many times but it allways ends up with the message "coppy error"
a similar probleme exist sometimes after saving a work file on my HD out of laser cut 5.5 and try to reload it to laser cut there comes the message " a unknown erroro occured the program shuts down" its not allways but also with different files.
what is this " U file" system good for and the U file connector if it does not work??
especially if you have a file with the right settings in the working and you can not save it from the DSP.
maybe this is another probleme with the software I dont know, maybe somebody else has figured it out
please let me know
Hello:
I have chat with the programmer and showed him the problem. He said that he would work out an upgrade patch to solve that issue.
Problem: Can't save file from the main board (through LCD panel) to a memory stick (dump drive)
Solution: Working on a patch to solve this issue.
Alternative: Save the job file to PC and then copy the file from PC to the dump drive will work
Post by waltfl »
hallo marco,
first thanks! I try this saved the file from my hardrive to the USB stick and inserted the USB stick in the DSP but if I try to open it it says " no Udrive" .
just that he looks in to it too.
Tech_Marco wrote:Hello:
Try to format the memory stick wiht FAT32 and try again
Also, do clean up on the main unit then cycle off the power and try again
Post by waltfl »
hi marco
I did all of this already a few times I also format the memory in DSp nothing changed except that I lost all my files what was in ther allready.
Tech_Marco wrote:Try to format the memory stick wiht FAT32 and try again
