Pause function stopped working on 2012
Engineerable
Post by Engineerable »
The Pause functionality has stopped working on the DSP 2012. It worked when I first installed and tested the system, but it stopped working shortly after. Now if I press "Start/Pause" while the laser is running, most of the time nothing happens. Sometimes the laser stops for a moment, then moves to a random location, and starts again. It also looses its absolute position, and the XY axis needs to be reset.
Because it was working initially, it makes me think that something in the firmware needs to be reset. Is there a way to reset the firmware of the controller?
