Use clarification for JLD634 ramp/soak controller
ags
Post by ags »
Can I use the JLD634 Ramp/Soak controller to run a small kiln requiring 12 amps, 1500 watts? If not, do you carry a controller that will control this type of kiln?
Re: Use clarification for JLD634 ramp/soak controller
Need to sue an external SSR. 25A is ok but must attached to a heat sink
