Solar pump system for pond
reefhugger
Post by reefhugger »
I'm wanting to circulate the water in a 1/4 acre cow pond, I've chosen two of the 40 watt solar panels to wire together, and the EWP-D50C2465 (40 L/m 24V ) pump. I want to add a 24 volt battery to extend the time the pump will run, so I'm thinking the EPR-SO10A solar regulator will work. I know just about nothing, so this is some guess work. Do these components go together okay? Any advice is welcome. So I need additional components?
Re: Solar pump system for pond
How many hours are you expecting to operate daily?
How many hours of sunlight in your location available. In our area, Sacramento, CA, we have about 5.5~6 hrs daily sunligh in average
reefhugger
Thank you for the reply. I would like the pump to run about 10 hours per day. The area is completely open to the sky, and we (Central Florida) average around 7 hours of sun over the course of the year.
Curiousity: Will a solar pump be harmed if too little current is available like some AC motors will? Again, don't know what I'm talking about, so I may not use the right terms.
Return to “Electronics”
