HI
I am in the process to convert my 40WCO2 laser to the new DSP my question is does this DSP 2012
works with Coreldraw X5?
new DSP2012 and corel X5
dwessels
Re: new DSP2012 and corel X5
I also would like to start using coreldraw x5.
It would be be a welcome upgrade if it works together.
Thanks...
Thanks...
Hi Guys,
To my knowledge the new software will not work with Corel Draw X5.
You will just have to settle for X4 for now until the software is upgraded and I don't know when that will be. X4 is just fine for the laser.
Hi rich
I can not get the new DSP to connect to the computer the computer does not find the machine.
I ca also not find the USB driver for windows 7
I use corel X4 now and still does not work
maybe you know something
pleas ehelp me out
thanks
pleas ehelp me out
thanks
baccus61 wrote:Hi Guys,
In the mean time, only X4 is supported. Per Mr. Wei, writing code for X5 is undergoing and should be available on December
Greolt
Did the upgrade to Corel X5 happen as expected?Tech_Marco wrote:In the mean time, only X4 is supported. Per Mr. Wei, writing code for X5 is undergoing and should be available on December
Greolt
dkc
Installed Lasercad 5.8 which is supposed to support Coreldraw X5
Tried Tools/macro/run macro/
AWC macros did not show up in the pop up menu
Doc attached in Lasercad 5.8 is in Chinese.... no help
Hi there
I had the same probleme but then acidently I discovered that even without installing the macro it worked with coreldraw X5.
just try it.
another probleme was that if I try to install the choice " install lasercad 5.85 /coreldraw " it would not install the lasercut icon or not at all
so I used the single install lasercut without the coreldraw and it worked .
just try it.
dkc wrote:Installed Lasercad 5.8 which is supposed to support Coreldraw X5
Gadroc
I just ran the installer twice. First for base and second time for Corel version. Not sure if that was necessary, but it worked. As said the install instructions are not translated yet.
