2012 DSP - Stepper driver connection
dwessels
Post by dwessels »
Hi,
I am trying to get the new 2012 DSP wired in to replace my old DSP.
I am using Bart's 4 axis board. http://www.buildlog.net/documents/A40005_rev_1.pdf
The old DSP was connected with to the stepper driver with GND, Pulse+, Step+.
The new DSP does not have a GND pin for the stepper driver, it only has DC5V, Step, Dir.
What is the correct way to wire the two together?
twehr
Re: 2012 DSP - Stepper driver connection
Post by twehr »
dwessels wrote:Hi,
Ground is ground - get it someplace else on the board - likely the case itself is grounded, so you could use that.
