Well, I finally purchased the 2012 DSP controller, 40w power supply, and 24v power supply, (I already have the two steppers drives). Now I'm just waiting delivery..
My question, since I'm replacing everything with new power supplies, they will no longer work with the 220v water pump that came with the laser. What do you use as a water pump?
Thanks, Bob
PS- i know I'll be asking more questions on how to wire and configure this laser as I get into replacing the parts. Thanks in advance for the help...
Water pump??
Re: Water pump??
Hi
I just starting the conversion the last items will arive on monday, but I would like to kbow too what kind of waterpump to use after conversion or is it possible to set the two power supply on 220V and use then the original water pump?
the two power supplies ar ether for 110V ( hier us) or 220V switchable.
thanks
thanks
mstang64bb wrote:Well, I finally purchased the 2012 DSP controller, 40w power supply, and 24v power supply, (I already have the two steppers drives). Now I'm just waiting delivery..
Thanks, Bob
Re: Water pump??
http://www.lightobject.com/38Lmin-Mini- ... -P396.aspx
http://www.lightobject.com/65Lmin-Mini- ... -P401.aspx
http://www.lightobject.com/10Lmin-158GP ... -P511.aspx
Any one of these will work just fine. It's DC12V so forgot the 110V or 220V issue. Use the universal power DC12
Users browsing this forum: No registered users and 110 guests
