EWP-DC50B24130 420GPH DC24V (100'C) Brushless Water Pump
Specification
Power: DC12V~24V
Current: 3.6A@24V, 1.6A@12V
Output: 26L/m (420 GPH) @24V, 15.5L/M or 245GPH @ 12V
Pressure: 13m (39ft) vertiical (about 19psi)
Motor: DC 3 phase coil
Power: 86Watt @24V, 20Watt @ 12V
Intake: 22.5mm
Outlet: 22.5mm
Life span: > 20,000hrs @ 1600rpm~10,00rpm
Noise: << 39dB
Working Temp: << 55'C/ 130'F
Size(L*W*D): See "More images for the exact dimension"
Weight (net): 16.0oz
Wire connection: Brown + power, Blue - power
Speed control: Red wire: + 5V Black wire: Ground, Yellow wire
Click attachement pdf file for more info
EWP-DC50B24130 DC24V (100'C) Brushless Water Pump
admin
- Site Admin
- EWP-DC50B24130_Manual.pdf
- (99.08 KiB) Downloaded 1589 times
