1.5KW CNC Spindle 220V 24,000rpm
Just imported five of 1.5KW 220V spindle. Looks pretty good.
Specification:- Power: 1.5KW
- Voltage: AC 220V (must use an isolated transformer) or through a VFD
- Current: 5A (need to confirm this later)
- Shaft: 6002 axial
- RPM: 24,000/m
- Frequency: 400Hz max
- Vibration: 0.01mm <
- Accuracy: 0.025mm
- Cooling: water cool
- Size 80mm(diameter) * 188mm (length)
- Case: Stainless steel 304
- Intake/outlet: alumnium
- Power connector: GX16 water proof (1,2,3,4) = (U,V,W) where 4 =Ground
