We're developing a new DC power meter with data logging. It can save wattage usage for up to six months.All info can be view on a 128 * 64 dot matric LCD or communicate with a PC. The meter is capable to display the Watt-hrs on a graphic chart or send dtaa to a PC through RS485 communication port. The meter built with two alarm output for overloaded and underloaded.
The hardware desgined work is completed. Now, it's on the second phase: Software.
Sample should be availabe by the end of this month Jun 30, 2011, assuming everything is on the right track.
DC Power meter with data log and 128*64 LCD
Re: DC Power meter with data log and 128*64 LCD
Update (6/22/2011):
Progress:
-PCB completed
-LCD module installed
Next:
-Programming
Progress:
-PCB completed
Next:
-Programming
