4CH RF Wireless 1527
MTTom
Post by MTTom »
4CH RF Wireless 1527 Remote Control Tx/Rx Kit
I would like to control (4) audio input sources (ipods) & select a single device for output.
The mode of opperation I want is:
Press A => Ch 1 close // all other Ch open
Press B => Ch 2 close // all other Ch open
Press C => Ch 3 close // all other Ch open
Press D => Ch 4 close // all other Ch open
What is this mode named?
How do I program/wire?
Thank You
Re: 4CH RF Wireless 1527
When you said "Press", do you mean "Press and hold" or "Press and let go", two different things. If Press and let go, this is called "Toggle". If Press and Hold, this is called "momentary". You need to go to the Download section and download the manual
MTTom
Post by MTTom »
Press & let go.
I could not find a location for download, but did find some manuals from other posts. They did not help much.
All manuals list here
MTTom
Post by MTTom »
Where are the manuals?
There was no link.
Sorry, empty link copied. Here again:
viewforum.php?f=15
Didn't you got there and found the manual?
MTTom
Post by MTTom »
Yes, I read that manual.
I did not understand.
In latch mode will:
Press A & release => Ch 1 close // all other Ch open
Press B & release => Ch 2 close // all other Ch open
Press C & release => Ch 3 close // all other Ch open
Press D & release => Ch 4 close // all other Ch open
Thank you for your patience.
I think I already explained it from my last email, yours is "toggle" mode. You should try each model yourself to get familiar with the modes. Just do the jumper switching, not hard
MTTom
Post by MTTom »
This is information from: http://www.carymart.com/index.php?main_ ... cts_id=313
Model No.:S4L-DC09 / S4L-DC12 / S4L-DC24
Control Mode: Latched (Press -> On, other channels Off; Press other button -> Off)
Latched: Press button 1: turn on relay 1, other relays turn off
Press button 2: turn on relay 2, other relays turn off
Press button 3: turn on relay 3, other relays turn off
Press button 4: turn on relay 4, other relays turn off
Will your model do the same?
I prefer your kit because it is in stock in USA & buttons are better arranged.
