Not sure if I got my JLD612 wiring correct to an SSR,, would like some inputs on this..
thanks,
wiring JLD612
robinhood
Re: wiring JLD612
Looks like you've got the SSR control signal wired backwards -- reverse the connections at the JLD612 or at the SSR -- doesn't matter which. + goes to +, and - to -.
robinhood
Re: wiring JLD612
do you mean that the 3 and the 4 should be flipped ?
robinhood
Re: wiring JLD612
guess mistakenly I am showing the 3 and the 4 reversed on the SSR...in haste of drawing this...hmmmrobinhood wrote:do you mean that the 3 and the 4 should be flipped ?
