Steeper current adjustment?
realtracks
I just received the 3 axis stepper driver and it appears there is no current adjustment for the steppers. Does it have the ability to adjust current on the board?
Re: Steeper current adjustment?
Formula: Vref/5Rsrealtracks wrote:I just received the 3 axis stepper driver and it appears there is no current adjustment for the steppers. Does it have the ability to adjust current on the board?
Vrf = Voltage at pin#10
Rs= the current resistor (the bigger one you seem on the board, usually 2Watt)
Example:
1.0ohm = 1A
0.39ohm = 1.25A
0.3ohm = 1.5A
realtracks
O.K. I expected it to be adjustable with a pot and vref like the rest of my drivers. My fault for not confirming before purchase. I did not expect to have to modify the board to adjust the stepper current.
Thanks for the reply
Miles
Miles
