Target for beam alignment
This is a design for a "target" for CO2 laser machines that do not come with a mounting plate to hold a paper sticker for beam alignment. It is free to download. You cut the target on a '1mm' transparency acrylic sheet and outline it with a lower power setting.
- CO2 alignment target v2.dxf
- (77.74 KiB) Downloaded 424 times
- CO2 Target plate.PNG (34.56 KiB) Viewed 4907 times
