im looking to keep the water chiller set at 20 degrees max and 18 degrees at lowest
what is the proper settings? i can go in with 0001 and change thing s but wanted to make sure i didnt mess anything up because there is a low cooling mode
chiller 600 model
chadfarmer
Re: chiller 600 model
Set AH1 to 20, AL1 to 18. But the performance of the tube will not change much, not much benefit of doing that.
