DSP controller works astably
asbest
Post by asbest »
Hello!
When I am adjusting DSP using "RLaserCut V 2.0" program - everything is o'key. But the next time DSP doesn't remember last tasks(adjusts). I have to adjust DSP every time again.
I use CorelDraw 14, password gxfc88.
Thanks.
twehr
Re: DSP controller works astably
Post by twehr »
asbest wrote:Hello!
Unfortunately, the software does not keep that information the way you would like it to. Since the document is actually a CorelDraw document, there is no way for RLasercut to add that info.
However, you can save the entire job and rerun it as often as you like. I believe everything will be retained.
After you run it the first time (and are satisfied that the settings (speeds, powers, etc) are correct, you can (in the main portion of the RLaserCut window) click the Save button and give it a name. You can then reload that same "job" and run it exactly as it was before.
BTW - the password you gave is for writing general machine parameters to the controller, so you should only be doing that process once, when you are first setting the whole system up to run with your drivers, motors, etc. It is not to be adjusted on a job-by-job basis.
Try this and let us know how it works for you. Hope this helps.
tim
