I'm having trouble getting sizing correct
Austinmn
Post by Austinmn »
I just installed the X7 on a new machine I have been building. I am running Raycam V19 and I am able to control the machine from the computer, but I am not able to get adjustments made to the Axis'. I started out being able to adjust them, but for whatever reason I am not now. I read the current parameters, then adjust, then save and am not able to change the Mu/Pulse setting. It just reverts to 1.0000 everytime. Also, another thing that I noticed the apply button at the bottom right of the parameters window is greyed out and has never been available to me.
Re: I'm having trouble getting sizing correct
"um" can't be used for value less than 2
You need to change microstepping on motor drivers.
I recommend 4000-5000 when setting drivers
Austinmn
Post by Austinmn »
Thank you.. I will switch it up
