Hey All,
I've found that my bed isn't level, what is the correct way to go about leveling it? Any documentation?
bed leveling procedure/instructions for LO PR 530
designfactore
Re: bed leveling procedure/instructions for LO PR 530
Lose belt tension on the Z and make sure each rod can be moved freely. Then adjust the level on each rods necessary by turning the rod clockwise or counter-clockwise. Once level is set, tight the belt tension on the Z by adjusting the tension adjuster.
BTW, prior to do leveling on the Z table, you need to make sure that the desk that the machine is sitting on must be leveled. Otherwise, you won't be able to get good leveling by adjusting the rods
