Engraving problems with AWC608C controller?
htrowrod
HELP!, I swapped out my controller on my laser for an AWC608c Controller a couple of years ago. This machine is mostly used as a hobbyist machine. It worked great up until 5 or 6 months ago. I tried generating a file using different software nothing helped.
Here is what is going on with the picture I have uploaded.
Picture #1..The letter “B” is raster cut then the box is cut with the Letter “B” centered in box. (Everything cuts correct and is the proper size and location)
Picture #2.. First the letter ”B” is engraved. Notice the size is stretched in only the Y axis. Then the box is cut around the letter. Notice the box is shifted down also. If I cut the box first it would be lined up with box in picture #1
I have generated a file using only Laser Cad same problem. So, it is probably not a Corel Issue.
OK, now here is the questions. Could the DSP control software be the issue? I downloaded the latest version of Laser Cad didn’t help. Might Light Burn Help?
Is it the controller? Marco, Could I bring the controller in and have you test it? I would be willing to pay for diagnostic fee, or Do you have a controller that I can borrow to test this with.
Thanks for reading this! All help will be greatly appreciated.
Bruce
Bruce
Re: Engraving problems with AWC608C controller?
Can you post screenshot over user and manufacturing parameters here so that I can review.
What you want to do is to draw a long box say X:10, Y:100. Then, do it over engraving and another next to it for cutting. Compare the result. I guess the one with engraving on it could end up longer than the cut.
Let me know
Let me know
htrowrod
Thanks Marco, I will get those photo's tonight.
Bruce
Bruce
htrowrod
Ok Marco here are the photo's you asked for. Please let me know if you need something else.
Bruce
Bruce
- IMG_06111.jpg (63.36 KiB) Viewed 46934 times
- IMG_06081.jpg (83.09 KiB) Viewed 46934 times
- IMG_06071.jpg (58.98 KiB) Viewed 46934 times
- IMG_06061.jpg (69.6 KiB) Viewed 46934 times
htrowrod
Marco on the letter "B" I posted earlier the cut "B" was 2.7" tall. The engraved one ended up being 3" tall
mrsunnylam
I notice the pulse edge on both (X) and (Y) axis is set to rising edge. could you change that to falling edge? and retest
htrowrod
Thanks for the response. Should I change just one or should I change both?
mrsunnylam
htrowrod
This is ,my daughter's laser and she hasn't had a chance to try the change to laser settings. I will keep everyone informed.
Bruce
Bruce
n8hawes
Ok, we changed both to falling edge and did the same test with the rectangles...same results as before. The engraved one is longer.
mrsunnylam
it is possible that your stepper motor driver and/or you motor may be going out.
htrowrod
Marco, did I post the right pictures that you asked for?
htrowrod
Thanks for the post Mr, Sunnylam, There is no issues when you cut a square using both. Only changes when you engrave.
htrowrod
Help?
Marco, are you out of town or what you asked me to post pictures which I did a while back. I got one reply on a setting which made no difference.
So, is it the controller? Once again Marco, Could I bring the controller in and have you test it? I would be willing to pay for diagnostic fee, or Do you have a controller that I can rent/borrow to test this with. Can I buy just the controller?
This is my daughters laser and I hate to see it just sitting there and not being able to engrave on it. I talked them into buying this controller from you because you are a local company and you and your team speak English in case we need help.
Bruce
Bruce
jlc2161
Hi there, It seems that your Y um is off when engraving, I would also suggest the built-in ‘um’ calculator on the LaserCad to find the correct ‘um’ value, draw a square 100 mm X 100 mm, cutting, then engrave to make sure it remains within the square.
Also have you try swapping drivers?, plugging the Y stepper motor to the X stepper driver and the X motor to the Y driver. Try engraving and see if the same problem remains.
