I am doing the t9 upgrade on my k40 and this is the power supply I have( the second one,green connectors).
https://www.everythinglasers.com/forums ... pply-info/
Do I use the 24v on the main power supply or use the one that came with the upgrade kit. Thanks
power supply and dc24v
javaman
mrsunnylam
Re: power supply and dc24v
you would use 24vdc to power the T9 controller if you are using your old power supply.
