RayCAM Manual Order
anable
RayCAM Manual Order
Post by anable »
Why does this feature not work? I reorder a single cut but nothing I do makes it stay. Seems like it should be a pretty simple process.
Re: RayCAM Manual Order
Probably you still have "Re-Order Objects" checked when you 'download' the file to the DSP. You need to unchecked this feature if you want to manually change order of the cutting pattern
Users browsing this forum: No registered users and 44 guests
