I have the LO-x7 connected to the AWC708C both cables are CN1 and CN2 are connected. I verfied that i have 5V coming out of K- and when i press the test fire button on the LO-X7 it goes low and have it tied to TTL on the awc708c. I have G and K+ tied together to GND on the awc708c. (verfied with a dvm that they are tied together). I have pwm connected the awc708c tied to IN on the PSU. I have P and G on the PSU tied together. Alos when i push the "test Fire" on the PSU the laser fires. Trying to get some idea where to look next.
Laser will not Fire
Re: Laser will not Fire
It is so confused here, you have two controllers ?
waterprotect?
lvmymp5
Found the problem it was the water protect circuit. The wires broke off when i tied it together. Thanks
Users browsing this forum: No registered users and 56 guests
