Manuf. Parameters, "Apply" box is not active
marko53
Post by marko53 »
Hello,
When working with the parameters the "Apply" button never becomes active. I have tried making changes, then hitting Read, then Save, then Resett on the DSP. The changes don't seem to take affect on the movement of the laser head or the function of the keys on the DSP(they are opposite to what they should be). Thanks, Mark
Re: Manuf. Parameters, "Apply" box is not active
What you need to do is "Read, change, then Save". It will ask you for the password. Put down "608" and Reset the controller, the new setting should be taken in effect.
marko53
Post by marko53 »
Knowing the sequence of saving the changes helped. Thanks
Return to “DSP E5”
