EMI Filter
robstach2
EMI Filter
Post by robstach2 »
Hi folks,
First post .. in the middle of planning my build and waiting on the rest of my shipment.
So, as per advice from LO, I ordered the AC EMI filter. I am assuming those goes in line with the laser PSU but I see the line side has 3 prongs and the load side has 2 prongs.
Does anyone have a nice photo or suggestion on the proper wiring procedure for this? Not wanting to take any chances.
Rob
Re: EMI Filter
The case is 'Ground' and it is common to the 3rd prong on the live side. You may double check it with a DVM meter with resistance measurement or continuity check.
robstach2
Re: EMI Filter
Post by robstach2 »
Got it - so, just run FG to case .. thanks!
