With an integration hybrid laser system, Lightobject proudly announced a new member of laser machine that cut metal and non-metal like wood, acrylic, or clothes and more.
With a 130W, it can cut through 1mm stainless or 3mm mild steel at 10mm/s without hesitation. If you want faster cut or cutting thicker metal, for a little more of upgrade to 150W. After upgrade, you can reach 15mm/s or cut 1.5mm SS or 4.5mm mild steel! Don't forget that it can be used to cut 18mm wood or 8mm acrylics as well.
http://www.youtube.com/watch?v=9N0qJP42dv4
Lightobject 130W CO2 Hybrid cutting machine for metal and non-metal
