What Stepping Motor Driver Should I buy ? U-axis . . .
litterbox99
Post by litterbox99 »
I plan on buying;
http://www.lightobject.com/High-Precisi ... -P795.aspx
What driver should I buy using a DSP X7 w/RayCam . . . ?
Re: What Stepping Motor Driver Should I buy ? U-axis . . .
You can get 3MD560 or 3MD580, any 3 phase motor driver capable to supply 4A or more current would be fine
litterbox99
Thank You Marco,
I was confused if it had a 2 or 3 phase motor, because the Web description said;
This is a quality made rotary with 2:1 reduction gear. The platform is anodized aluminium and it is driven by a " 2-phase " stepping with 1.8degree precision.
and the Specifications said;
- Motor: NEMA 23 3 phase 573S15 5.2A 212in-oz Stepper motor
We changed it to 3 phase motor because all our laser machine are now using 3 phase. I will have to correct the item description, thanks for the info
