I'm looking at the 900x600 XY stage, and it looks to be square aluminum bar. How would that mount to the Aluminum Frame Kit or a DIY frame?
Or is it now made out of the same 3030 t-slot the frame is made out of?
How does XLE XY Stage mount to frame?
jezter6
Winstonc
Re: How does XLE XY Stage mount to frame?
There are holes in the bottom of each end of the square tube and you mount it to the extrusions using the normal bolt and square nut.
Hope that helps
David
Hope that helps
David
jezter6
Thanks WinstonC. Standard M5x8mm bolts?Winstonc wrote:There are holes in the bottom of each end of the square tube and you mount it to the extrusions using the normal bolt and square nut.
Hope that helps
David
Winstonc
I just used the same bolts that came with my extrusion kit which where m6 x 12mm.
David
David
