Engraving problem
chippypah
Engraving problem
Post by chippypah »
Hi all, got a problem on my LO-X7 when engraving. I must have changed something but not sure where, it is engraving one letter at a time now any thoughts on what to change
Cheers
Pete
Re: Engraving problem
It is a setting.. I thought it is on the page when you download a file to the laser, something about reorder or optimize, something..
Agreed, I think there is a setting on "Download" and you can check on it I forgot what is that but I will check it and post what I found
chippypah
Post by chippypah »
Great thanks.
Cheers
Pete
At the other hand.. It can speed up engraving.. if the characters are spread over a wide object, the laserhead has to travel quite a distance without engraving.. Only when all characters are set close together it can be a bit slower in total..
chippypah
Post by chippypah »
Found as you said in download file, thanks for the help.
Cheers
Pete
