I have my kit on the way and have redrawn the constructed kit in Fusion 360 so I can use it as a basis for the rest of the build.
Based on the LO setup diagram, there seems to be a discrepancy in one of the dimensions as follows:
1. Assuming on the second horizontal level from the bottom that the distance between the 2 "d" lengths on the left hand side is equal to the dimension of the "l" lengths
2. Assuming on the second horizontal level from the bottom that the distance between the 2 "d" lengths on the right hand side is equal to the dimension of the "i" lengths
The length of part "e" should be the same as the length of part "f", however it is 5mm longer (805mm vs 800mm). Is this an error or have I made an incorrect assumption?
Thanks for the help.
David
Aluminum Frame for 600 x 400 kit
Winstonc
Jump to
- Special note
- Administrative Category
- ↳ New Product on the board
- ↳ Latest News
- Sell & Wanted
- ↳ Laser products
- ↳ CNC products
- ↳ Electronics products
- ↳ Others
- ↳ Repair & Upgrade
- ↳ Product Lab
- ↳ Cutting & Engraving tips
- ↳ FAQ (laser)
- ↳ AWC7824
- ↳ AWC7813
- ↳ Ruida R6445G/X
- ↳ DSP T9
- ↳ DSP X7
- ↳ DSP R5
- ↳ DSP E5
- ↳ DSP 608
- ↳ CO2 Laser Discussion
- ↳ News
- ↳ Auto focus laser head
- ↳ Introduction
- ↳ CNC zone
- ↳ Temperature Controller
- ↳ Electronics
- ↳ RF Wireless Controller
- ↳ Digital/ Analog Meter
- ↳ Laser & CNC products
- ↳ DSP controller
- ↳ Water Chiller
- ↳ Laser power supply
- ↳ XY gantry and frame
- ↳ Motor driver
- ↳ K40 small laser
- ↳ LCD Module
- ↳ AC Power Frequency Meter
- ↳ Other electronics devices
- ↳ Water pump
- ↳ LED
- Software Download
- ↳ DSP Laser Controller
- ↳ Fiber Laser
- ↳ Flying
- ↳ Others
