LO LPSU 5v output
Winstonc
LO LPSU 5v output
Post by Winstonc »
What is the 5v output for on the LO laser power supply for? Can I use it to power a LED laser pointer for aiming?
David
Re: LO LPSU 5v output
It is for analog power control
If the red dot laser take less 50mA(most likely) I see no reason why can't you to use.it to power the laser pointer
Winstonc
Post by Winstonc »
Thanks Marco.
