Power and speed settings not sending to laser
SonicDad
Post by SonicDad »
Hi All,
I've upgraded my K40 laser with the X7 DSP upgrade kit and have cut the duck out of foam board as well as engraved a panel design from LaserCad. My issue now is that when I set the power/speed to cut in LaserCad and send it to the K40 the file gets there and the laser works but the default power/speed settings never change on the laser. No matter what power/speed I set the software to, the laser stays at the default. Any assistance would be much appreciated.
SonicDad
Re: Power and speed settings not sending to laser
Check your connection: TTL and PWM
You may reversed the connections so that output is always High and not changeable
