Hello,
does anyone know, which cind of File I have to put on the USB-Stick that it will work.
Do I have to use the
"SaveToUFile" button in the cutting software?
I tried this, but it didn´t work. I alwas says, that there is nothing on the USB.
lanoph
File on USB-Stick
Re: File on USB-Stick
I think you need to format the USB stick to FAT 16 or 32. I'm not really sure which one but I remember reading something like that a while ago. You can try out each one as it only takes a few seconds to format the stick.
Let us know if it works and share the info if you get it working so others may benefit too.
